Skip to content
For the complete Netlify documentation index, see llms.txt. Markdown versions of this page are available by appending .md to the URL.
Unlimited seats on Netlify Pro for $20/month β†’ Learn more πŸ‘₯
Local development with Netlify CLI
For the complete documentation index, see llms.txt
The Netlify CLI brings the functionality of your Netlify production environment directly to your local machine through the dev command. This CLI functionality is also referred to as Netlify Dev.
When you use Netlify Dev, the CLI provides a proxy server that includes edge logic for custom headers and redirects, environment variables, and Netlify Functions. It automatically detects tools and frameworks like Gatsby, Hugo, Eleventy, Next.js, and more to configure a local development server that mimics the Netlify production environment.
The sections below describe how to get started with Netlify Dev, how project detection and ports work, and how to customize the configuration.
You can also access the command reference for dev for more information.
Before you begin, make sure you complete the following if you haven't already:
  • Install the Netlify CLI.
  • Authenticate with an access token.
  • Link your local project to a Netlify siteID (also called Project ID in the Netlify UI). To do this:
    • If you're joining an existing project, use netlify clone <repo> to clone and link in one command (recommended)
    • If you're setting up a new site, use netlify init to set up continuous deployment
    • If you've already cloned a repository manually, use netlify link to connect it to a Netlify site
To start a local development server for the build tool you’re using, run the following command from the root of your linked repository:
Terminal window
netlify dev
By default, Netlify Dev runs your project using the configuration and environment variables set for local development with the Netlify CLI. For environment variables, that means those with values set for dev or all deploy contexts. You can use the --context flag to run your project with a different deploy context’s settings and variables.
Terminal window
netlify dev --context production
Note that environment variables apply to all scopes when running netlify dev.
To run a shell command within the Netlify Dev environment, use exec:
Terminal window
netlify dev:exec YOUR_SHELL_COMMAND
Netlify Dev attempts to detect the site generator or build command that your project uses and run these on your behalf, while adding other development utilities. If you have a JavaScript project, it uses simple heuristics to search for the best package.json script to run for you, so you can use the full flexibility of npm scripts.
You also have the option to override framework detection, if needed.
When you use Netlify Dev, you may encounter a few different ports β€” especially if your project uses a static site generator that has its own dev server, like Gatsby. Keep the following in mind when working with Netlify Dev:
  • If your project uses a framework that we can detect, Netlify Dev will use the framework's conventional ports, so you don't have to supply them yourself. If multiple detectors match your project, we'll ask you to choose.
  • If your site generator runs on a specific port, such as port 8000, you need to specify the port when you run netlify dev. Netlify Dev will connect to that port and route requests successfully to the site generator along with the rest of the local Netlify environment.
  • If you use an unrecognized site generator or framework, or have a server you want Netlify Dev to connect to, you need to specify the port when you run netlify dev.
To confirm which port to use for local development with Netlify Dev, search for this box in your console output:
Terminal window
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ β”‚
β”‚ [Netlify Dev] Server now ready on http://localhost:8888 β”‚
β”‚ β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
Netlify Dev works without configuration for the majority of users, but you can customize Netlify Dev settings in the [dev] section of the Netlify configuration file. The following sections outline some common configuration options.
For a full list of the available properties, refer to the Netlify Dev section of our file-based configuration doc.
By default, netlify dev starts an HTTP server. If you require HTTPS, you can configure a certificate and key file for use by netlify dev in your netlify.toml:
[dev]
[dev.https]
certFile = "cert.pem"
keyFile = "key.pem"
Netlify Dev allows you to specify custom ports using the following parameters as flags or in a Netlify configuration file (netlify.toml):
  • targetPort: the port for your application server, framework, or site generator
  • port: the port for the Netlify Dev server that you will open in the browser
Netlify Dev tries to acquire these ports but if they are already in use by another application, it will throw an error and let you know.
[dev]
targetPort = 3000
port = 8888
