Manage visual editing for a site
As a Netlify Owner or Developer, learn the basics of managing visual editing for a site using the Netlify visual editor.
# Enable visual editing
Once a site has visual editing enabled, you can either test out visual editing if your site is already pre-configured or you can follow the configuration steps to complete the setup.
As a Developer or Owner, to enable visual editing for an existing site on Netlify:
After a successful deploy of your site, go to your site configuration page in
app.netlify
and select Enable visual editor.Select Enable visual editor.
From your visual editor settings page, you’ll find the setup walkthrough in the Netlify UI that prompts you for the next steps. Note that you may not need to complete all of these steps, depending on how much your site is already pre-configured for the visual editor.
For additional guidance, check out the visual editor walkthrough help doc.
# Find a site with visual editing
To find a site with visual editing enabled:
- From your Team Overview, go to your visual editor dashboard for your team.
Or from your sites list in the Netlify dashboard, you can append visual_editor=true
to the URL search parameters. For example, this URL https://app.netlify.com/teams/YOUR_TEAM_NAME/sites?visual_editor=true
will return sites with visual editing enabled.
# Manage access to visual editor
To manage access for the visual editor, you must have certain permissions. Learn more in Editorial permissions.
# Open the visual editor
When visual editing is enabled for a site, you can access the visual editor through the following:
- the navigation after you select a site in the Netlify UI
- in the site details card
# Find the working status of the visual editor
The working status of the visual editor is shown near the site details card in the Netlify app UI. You can also find a status update in the visual editor interface.
# Disable visual editing
To turn off Netlify’s visual editor functionality for a site:
As a Developer or Owner, go to your site configuration page in
app.netlify
.Select the Disable the visual editor button and confirm you want to stop visual editing for the site.
Did you find this doc useful?
