Skip to content
Start your next project with a prompt. → netlify.new 🚀
Debug with VS Code and Netlify CLI
You can use the VS Code debugger while you run your project with the Netlify CLI. This document outlines how to configure VS Code and how to launch the debugger.
Create a launch.json file under a .vscode directory in your project with the following content.
"version": "0.2.0",
"configurations": [
"name": "netlify dev",
"type": "node",
"request": "launch",
"skipFiles": ["<node_internals>/**"],
"outFiles": ["${workspaceFolder}/.netlify/functions-serve/**/*.js"],
"program": "${workspaceFolder}/node_modules/.bin/netlify",
"args": ["dev"],
"console": "integratedTerminal",
"env": { "BROWSER": "none" },
"serverReadyAction": {
"pattern": "Server now ready on (https?://[\\w:.-]+)",
"uriFormat": "%s",
"action": "debugWithChrome"
"name": "netlify functions:serve",
"type": "node",
"args": ["functions:serve"],
After you create the configuration file, launch the debugger:
  1. Select Run and Debug from the VS Code sidebar. To reduce noise, we recommend that you deactivate Caught Exceptions.
  2. In the top menu, select the command to run — either netlify dev or netlify functions:serve
  3. Run the debugger.
If you select netlify dev, the CLI will start a local development environment and open a browser with the site URL. If you select netlify functions:serve, the CLI will start a standalone Netlify Functions server.
Use the --inspect Node.js option to debug functions. Visit managing functions for more information.
