Integrate & extend /Integrations /
Netlify Email Integration
The Netlify Email Integration connects your Netlify site with popular, API-driven email services and allows you to manage version-controlled email templates alongside the rest of your project code. Use the Netlify Email Integration to generate email function handlers that populate custom email templates and send emails using a specified email API provider.
# Before you begin
  • Set up an account with one of the supported email providers listed below. The integration uses an email API.
  • Ensure your account is verified by the email API provider.
  • Ensure that you have provided authorization to send emails from the email address you wish to use as the sender.
  • Note your API key from your email API provider.
# Supported email providers
You can use the Netlify Email Integration to connect your Netlify site with email APIs from these providers:
# Enable Netlify Email Integration for your site
The Netlify Email Integration is automatically installed on all teams, so you just need to enable it on the individual sites you want to use it with.
Follow these steps to enable the Netlify Email Integration for your site using the Netlify UI or file-based installation.
# Enable with the Netlify UI
  1. In the Netlify UI, under Sites, select the site you’d like to enable the Netlify Email Integration on.
  2. Navigate to
  3. Select Enable email extension.
  4. Complete the setup:
    • select an Emails provider
    • enter an Emails provider API key
    • if you’re using Mailgun, enter the Mailgun domain and Mailgun host region
    • optionally, set a custom Emails directory
    Then select Save.
  5. Deploy your site so that you can use the integration.
# Enable with netlify.toml
  1. Add the integration to the plugins section of a netlify.toml file stored in your site’s base directory.
    [[plugins]]
      package = "@netlify/plugin-emails"
  2. Add the required environment variables. We recommend using the Netlify UI, CLI, or API for this step.
  3. Deploy your site so that you can use the integration.
# Required environment variables
When enabling the integration using netlify.toml, certain environment variables are required to complete initial configuration. If you have the option to set specific scopes for your environment variables, the scope must include both Builds and Functions to be available to the build system and to functions.
Variable Name Description Required
NETLIFY_EMAILS_PROVIDER Valid values:
mailgun
sendgrid
postmark
Yes
NETLIFY_EMAILS_PROVIDER_API_KEY API key issued by the email provider Yes
NETLIFY_EMAILS_SECRET Unique secret used to authenticate that a request to the email API provider is genuine Yes
NETLIFY_EMAILS_MAILGUN_DOMAIN Domain used by Mailgun Yes, if Mailgun
NETLIFY_EMAILS_MAILGUN_HOST_REGION Valid values:
non-eu
eu
Yes, if Mailgun
NETLIFY_EMAILS_DIRECTORY The default directory path is ./emails but you can set this variable to change it No
# Add email templates
To add an email template, add a file at the appropriate location and set up the contents and styling for the template.
# Add a template file
To add an email template to your project:
  1. Create an emails directory in the base directory for your project.
  2. Create a subdirectory for your template. The subdirectory name should represent the expected route of your template.
  3. Create an index.html file within the subdirectory. Alternatively, you can create your own template using MJML.
Here’s an example file structure for a subscribed email:
repository-root or base directory/
├─ emails/
│  └─ subscribed/
│   └─ index.html
The default emails directory is YOUR_BASE_DIRECTORY/emails.
To optionally configure a custom emails directory, set the NETLIFY_EMAILS_DIRECTORY environment variable or update the directory value in the Netlify UI:
  1. Visit .
  2. Select Configure and enter a custom Emails directory.
# Add HTML to the template
The template file accepts HTML and must include <html> and <body> tags.
If you want to use variables in your email template, you can use handlebars.js syntax and pass the arguments in the request. The variable values will be injected when the email is triggered.
Here’s a sample email with a parameter:
<html>
  <body>
    <h1>Welcome, {{name}}</h1>
    <p>We hope you enjoy our super simple emails!</p>
    <p>Thanks for subscribing!</p>
  </body>
</html>
# Style the template
You can also add custom styling to your templates. To do this, add inline CSS blocks using the style attribute inside the HTML elements of your template file.
<html>
  <body
    style="
      font-family: 'Open Sans', 'Helvetica Neue', sans-serif;
      margin: 0 auto;
    <div
      style="
        background-color: white;
        display: inline-block;
        text-align: center;
      <h1>{{name}} has RSVP'd</h1>
      <button style="border-radius: 10px;">
        Visit dashboard
      </button>
    </div>
  </body>
</html>
# Create a template with MJML
The Netlify Email Integration supports templates created with MJML. MJML enables you to create templates that are responsive and compliant across most browsers. To create an email template using MJML, save your template file as index.mjml instead of index.html.
Visit the MJML documentation to learn more about styling your template.
# Preview email templates
You can preview your email templates during the development process by launching the Preview UI.
The Preview UI generates the template-specific code snippets you’ll need to send a request to the email handler when you trigger the email. Use the Netlify CLI to launch the Preview UI and generate this code.
  1. Ensure you have the latest version of Netlify CLI installed:
    npm install netlify-cli -g
  2. Build your project.
    netlify build
  3. Launch Netlify Dev to start a development environment that can run your email preview:
    netlify dev
  4. Visit http://localhost:8888/.netlify/functions/emails to launch the Preview UI.
    The preview endpoint is not available in production and is only made available locally through Netlify Dev.
  5. Select your email template from the template list.
    open preview of email template.
# Send a test email from the Preview UI
When you launch the preview, you can send a test email directly from the Preview UI. To trigger the test email:
  1. Select the email template you plan to test from the available templates.
  2. Optionally, enter any parameters you’d like to preview.
  3. Select Send test email.
  4. Enter your subject, to, and from parameters.
  5. Select Send, which will send the email from your email provider.
# Trigger an email from your code
When you preview your email template, Netlify generates two code snippets that you can use to trigger an email:
  • @netlify/emails: snippet that utilizes a package
  • fetch: snippet that contains the raw fetch route and an environment variable
preview of email template with generated fetch function.
To trigger an email directly from your project code, copy and paste your preferred snippet into your project and populate the parameters for your email.
# Create a function to send the email
Because the snippet generated in the preview contains an environment variable, NETLIFY_EMAILS_SECRET, we recommend pasting the code snippet into a Netlify Function to avoid sharing sensitive information in client-side code.
You can learn more about the format of functions on the get started with functions. The function file should be in your netlify/functions directory. Following the fetch code example below, this example file’s path would be netlify/functions/triggerSubscribeEmail.ts.
import type { Handler } from "@netlify/functions";
import fetch from "node-fetch";
const handler: Handler = async function(event) {
  if (event.body === null) {
    return {
      statusCode: 400,
      body: JSON.stringify("Payload required"),
  const requestBody = JSON.parse(event.body) as {
    subscriberName: string;
    subscriberEmail: string;
    inviteeEmail: string;
  //automatically generated snippet from the email preview
  //sends a request to an email handler for a subscribed email
  await fetch(`${process.env.URL}/.netlify/functions/emails/subscribed`, {
    headers: {
      "netlify-emails-secret": process.env.NETLIFY_EMAILS_SECRET as string,
    method: "POST",
    body: JSON.stringify({
      to: requestBody.subscriberEmail,
      subject: "You've been subscribed",
      parameters: {
        email: requestBody.subscriberEmail,
  return {
    statusCode: 200,
    body: JSON.stringify("Subscribe email sent!"),
export { handler };
Next, you'll add an event in your code to call this function.
# Call the function from an event
There are many approaches you can take to triggering an email. For example:
  • A user clicks a button requesting information, subscribing to a newsletter, or updating their profile.
  • A user scrolls to the bottom of a blog post so you trigger an email to send them more information on that post subject or other posts.
  • A data event has reached a certain amount and you would like an email sent to notify your users.
Here’s an example of the code to attach the email trigger to a Subscribe button in a Next.js app. In this React example, the parameters for the template are set using user input from the form on the page. With this process, you can populate the parameters of your email templates with any data being passed to your site, like a form or data from API calls to a user database.
export default function Subscribe() {
  const handleSubmit = async (event: React.FormEvent<HTMLFormElement>) => {
    event.preventDefault();
    const target = event.target as typeof event.target & {
      name: { value: string };
      email: { value: string };
    const data = {
      subscriberName: target.name,
      subscriberEmail: target.email
    //call to the Netlify Function you created
    fetch("./.netlify/functions/triggerSubscribeEmail", {
      method: "POST",
        subscriberName: data.subscriberName,
        subscriberEmail: data.subscriberEmail,
        inviteeEmail: "info@netlify.com"
  return (
    <div className="subscribe-form-container">
      <form onSubmit={handleSubmit}>
        <label htmlFor="name">Name</label>
        <input type="text" id="name" name="name" required />
        <label htmlFor="email">Email</label>
        <input type="text" id="email" name="email" required />
        <button type="submit">Subscribe</button>
      </form>
    </div>
When the event is triggered, this invokes the function and the fetch call to an email handler. This handler prompts the email API service you configured to send the email.
# Add attachments to your email
When sending messages, you can also specify any files you’d like to attach.
  1. Make sure any files you plan to attach to an email are included when the function that sends the email is built and deployed. For example, to attach a PDF file saved in an assets directory, the project file structure could include a section like this:
    ├─ netlify/
    │  └─functions/
    │   └─ function.js
    │   └─ assets/
    │     └─ example.pdf
    └─package.json
    In this example, any PDF files in the assets directory would be included with the function using this netlify.toml entry:
    [functions]
    [function."function"]
      included_files = ["./nelify/functions/assets/*.pdf"]
    You can learn more in our blog post about including files in serverless functions.
  2. Using the snippet generated during the email preview, add the attachments property to the request body. The attachments property is an array that may contain three properties to attach your file: content, filename, and type.
    Property Name Type Description Required
    content string Base64 encoded string of the file Yes
    filename string The name of the file as it will appear in the email Yes
    type string The MIME type of content you are attaching Yes, if Postmark
    Using the example project setup above, the following handler function parses the PDF file saved in the assets directory. Nested in the body object is an attachments array that lists the content, filename, and type properties for that file.
    import {readFileSync} from "fs";
    import {resolve} from "path";
    const handler: Handler = async () => {
      const file = readFileSync(resolve("./assets/example.pdf"), ".").toString("base64");
      const response = await fetch(
        `${process.env.URL}/.netlify/functions/emails/forgotten-password`,
          headers: {
            "netlify-emails-secret": process.env.NETLIFY_EMAILS_SECRET,
          method: "POST",
            cc: "recipient@youremail.com",
            to: "recipient@youremail.com",
            subject: "Password Reset",
            attachments: [
                content: file,
                filename: "example.pdf",
                type: "pdf",
            parameters: {
      const responseBody = await response.json();
      return (
        statusCode: response.status,
        body: JSON.stringify(responseBody)
    export { handler };
Refer to your email provider’s documentation to verify which types of content are valid for an attachment.
# Limitations
Functions that call other functions on password-protected sites will get an error when calling the next function. If you’re using a password-protected site, you’ll likely receive a 401 error from your function that calls the email function. To avoid receiving this error, you need to forward the cookie from the initial function on to the email function.
Here is an example of a workaround for this limitation:
  const cookie = event.headers["Cookie"] || event.headers["cookie"];
  // Send netlify email with fetch
    `${process.env.URL}/.netlify/functions/emails/the-template-name`,
      method: "POST",
      headers: {
        cookie,
