Vue CLI is a set of tools for rapid development of Vue.js applications. It includes a command line interface for prototyping and building projects and a graphical user interface for creating and managing applications.
Key features
Section titled “Key features”These features provide important benefits for Vue CLI projects, including ones built and deployed with Netlify.
- Default setup. Vue CLI provides a standard baseline for project setup with common features like hot module reloading and common defaults for build tools.
- Ready for development. Built-in support for Babel, TypeScript, ESLint, PostCSS, Progressive web apps (PWAs), unit testing, and end-to-end testing unlocks your productivity.
- Optional configuration. Vue CLI allows for full configuration of tooling without needing to eject.
Netlify integration
Section titled “Netlify integration”When you link a repository for a project, Netlify tries to detect the framework your site is using. If your site is built with Vue CLI, Netlify provides a suggested build command and publish directory: vue-cli-service build and dist. If you’re using the Netlify CLI to run Netlify Dev for a local development environment, Netlify also suggests a dev command and port: vue-cli-service serve and 8080. You can override suggested values or set them in a configuration file instead, but automatic framework detection may help simplify the process of setting up a Vue CLI project on Netlify.
For manual configuration, check out the typical build settings for Vue CLI.
Vue-specific environment variables
Section titled “Vue-specific environment variables”Environment variables prefixed with VUE_APP_ are processed by the Vue CLI and made available in the browser for client-side JavaScript access. For more information on how to use environment variables in Vue, check out the Environment variables and frameworks doc.
More resources
Section titled “More resources”Did you find this doc useful?
