Inline editor
Inline editing removes the need for content editors to understand the structure of the content by enabling them to click directly on elements in the preview to make changes.
This guide introduces how inline editing works through HTML element annotations, along with common patterns for working these annotations. See the reference guide for further usage instruction.
# How inline editing works
Inline editing is made possible through annotating components. This involves adding one or more data attributes to help Visual Editor map content in the preview to the proper location in the proper content source, using the site's content schema.
export const ComposablePage = (props) => {
return (
<div data-sb-object-id={props.id}>
<h1 data-sb-field-path="title">{props.title}</h1>
</div>
<div data-sb-object-id="1">
<h1 data-sb-field-path="title">My Page Title</h1>
</div>
# Target generated HTML
It's important to note that Visual Editor works with the HTML code generated by your framework. It does not read the component code directly.
This means that you have to take care to understand how the HTML tree is built as a result of composing a page with framework-based components. More on this in common patterns below.
# Annotation types
There are two properties that make up an annotation:
- Object ID: The uniquely-identifying value representing a document in a content source, typically defined using the
data-sb-object-id
attribute. - Field Path: A field name or path representing the identifying value of the field in the content source where the content should be stored, typically defined using the
data-sb-field-path
attribute.
These properties work in tandem to help Visual Editor determine how to store content changes by first locating the proper document in the proper source, and then finding the field within that document’s model.
See the reference for specific usage details
# Use the DOM tree
Annotations follow the structure of the DOM tree, setting the annotation scope for all descendants.
In the example above, the <h1>
value was inferred to below to the document with ID 1
because the parent <div>
set its scope.
In the example below, the heading
field path is scoped to the document of ID matching the resolution of props.id
, while body
appears to have no scoped document and will prompt an error in the console.
// MyComponent.jsx
export const MyComponent = props => {
return (
{/* Scoped to `props.id` */}
<h2 data-sb-field-path="heading">{props.heading}</h2>
</div>
{/* Causes an error because there appears to be no scope for this field path. */}
<div
data-sb-field-path="body"
dangerouslySetInnerHTML={{ __html: props.body }}
Note
The body
path "appears to have no scope" because Visual Editor reads the resulting HTML generated by your framework and not the component code itself.
If a ancestral component generated HTML with a data-sb-object-id
attribute, then the body
field path would be scoped to that object.
# Work with object IDs
Object ID annotations are how Visual Editor identifies the document to edit for the current element, along with akk descendants of that element in the DOM tree.
# Object ID exceptions
Most content sources make a document's uniquely-identifying value obvious. Content source modules use this value to represent the document ID whenever possible.
Exceptions to this are listed in the appropriate content source integration guide.
# Rescope with Object IDs
Because we can take advantage of the DOM tree while annotating, this means you can rescope objects within other objects.
Suppose you had a post document that referenced an author document, and you wanted to be able to edit the author's name inline. You can rescope the document by adding a new object ID annotation while within the context of another document.
export default function Post(props) {
return (
<article data-sb-object-id={props.post.id}>
<h1 data-sb-field-path="title">{props.post.title}</h1>
<div data-sb-object-id={props.post.author.id}>
<span data-sb-field-path="name">{props.post.author.name}</span>
</div>
</article>
Note that title
is within the content of the post, while name
has been rescoped within the context of the author document.
# Work with field paths
Field path annotations are how Visual Editor knows how to map content within elements on the screen to fields in the content source.
# Map to model fields
Many websites contain components that do not have one-to-one parity to a data model. The properties for that component may not match the fields in the content schema, but may be transformed before being sent to the component as props.
However, field names specified with data-sb-field-path
must match field names in the schema, and not another variables or property name used to render the value.
For example, assume you have a document in the content source with a structure like this:
"id": "1",
"type": "Post",
"title": "Blog Post Title",
"body": "<p>Hello World</p>"
And suppose you were using a component called <Markdown />
that expected you to send the markdown string as a property called content
. If you hard-coded the field path, this would not work as expected.
return (
<Markdown content={props.body} />
</article>
export function Markdown(props) {
// Will not be editable unless the field name is `body` in the models
// making use of this component.
return (
<div
This doesn't work unless the field name for the property in the model is body
. In this case, you might want to expose the annotation as a prop.
// components/Markdown.tsx
return (
<div
data-sb-field-path={props.annotation || "body"}
# Absolute vs relative field paths
In most cases with most content sources, an annotation consists of an ID and field name.
Some content sources allow for nesting content within a single document. (Git CMS is the typical example.) In this case, objects of some model may be nested within a document of another model. Consider this content structure:
"id": "1",
"type": "Post",
"author": {
"name": "Stephen King"
In this case, author
is an embedded object, represented by a model, with a field called name
. The author object has no ID value, and can only be edited through the post object.
When annotating components, you can use dot notation to drill down into nested components. And when a field path begins with a dot (.
), it is assumed to be chained to its most recent ancestor. Otherwise, it is assumed to be an absolute path.
The two examples below would make author.name
editable inline.
return (
<div data-sb-field-path="author">
<span data-sb-field-path=".name">{props.post.author.name}</span>
</div>
</article>
return (
<span data-sb-field-path="author.name">{props.post.author.name}</span>
</article>
Note that this also works for arrays, where the index can follow a dot. Here's an example where a post had a list of authors:
return (
<div data-sb-field-path="authors">
{props.post.authors.map((author, index) => (
<span data-sb-field-path={`.${index}.name`}>
</span>
</div>
</article>
<article data-sb-object-id="1">
<span data-sb-field-path=".0.name">Stephen King</span>
<span data-sb-field-path=".1.name">Dr. Seuss</span>
</div>
</article>
# Combine ID with field paths
In situations where you don't want to add an element just to specify an ID, you can include the ID value in a field path annotation by separating it from the path with a colon (:
). Here's the example above, written in a single line.
export function Post(props) {
return (
<div>
<span data-sb-field-path={`${props.post.id}:author.name`}>
</span>
</div>
# XPaths for advanced patterns
In situations that require advanced controls over field paths, you can append an xpath to the field path following a hash (#
). Here's an example that makes the title editable, even though there are multiple other children.
return (
<div data-sb-field-path="title#text()[0]">
{props.title}
<span>...</span>
</div>
See more cases for xpath values in advanced patterns below.
# Common patterns
The following sections provide some instructions on the most frequently-used patterns when annotating components for inline editing.
# Annotate nested objects
Use dot notation to build a chained path to the proper field. Field paths that start with a dot are automatically chained to their closest ancestor. These two examples achieve the same result.
return (
</div>
</article>
return (
</article>
# Annotate list fields
List fields should use the index as a node in the field path.
return (
</span>
</div>
</article>
</div>
</article>
# Unable to use a parent element
When unable to use a parent element, the object ID value can be prefixed to the field path, separated by a colon (:
return (
<div>
</span>
</div>
# Nest fields within another object's scope
The context can be rescoped for an individual element by providing the ID with an absolute field path (as shown in the section above) or for all further descendants by annotating a new object ID.
Here's an example that rescopes all descendants of a div by specifying a new object ID.
return (
</div>
</article>
# Advanced patterns
The practices shown above are enough to handle the majority of cases on most sites. The following cases occur with less frequency, but are essential for maintaining the flexibility to build the DOM how it best serves your project.
# Multiple fields as the same child
It's often convenient to use multiple properties within a single element, such as combining an author's first and last names.
export function MyComponent(props) {
return (
<div className="author" data-sb-field-path="first_name last_name">
{author.first_name} {author.last_name}
</div>
It's much easier to work with structured content when each property get its own element. Use an inline element like <span>
and annotate each individually.
return (
<div className="author">
<span data-sb-field-path="first_name">{author.first_name}</span>
<span data-sb-field-path="last_name">{author.last_name}</span>
</div>
# Elements with multiple children
When an element renders a field value as its direct text node child, but also includes other elements as children, use the xpath to specify the exact position of the rendered field value within the element.
return (
{props.title}
<span>...</span>
</div>
# Elements that render multiple fields
In some cases, an element can render two fields from the same object. You can specify both fields separated by a space, applying the proper xpath as necessary.
return (
<div data-sb-field-path="title#text()[0] subtitle#text()[2]">
{props.title}
<span>...</span>
{props.subtitle}
</div>
Did you find this doc useful?
