Skip to content
Netlify Docs
For the complete Netlify documentation index, see llms.txt. Markdown versions of any documentation page are available by appending .md to its URL.
The new Netlify experience is here. Learn more or join the waitlist.
Disable project
Netlify allows you to disable your projects to take them offline while keeping your existing configuration. This is also an effective way to stop consuming resources like build minutes, functions or bandwidth.
Note that you cannot disable a project if the project is a public extension as this would break other projects using that extension.
As an Owner, to disable a project:
  1. Go to Project configuration Configuration Danger zone and select Disable project.
    Netlify UI location of disable project button
You can enable a project at any time.
As an Owner, to enable a project:
  1. Go to Project configuration Configuration Danger zone and select Enable project.
    Netlify UI location of enable project button
