Skip to content
Netlify Docs
For the complete Netlify documentation index, see llms.txt. Markdown versions of any documentation page are available by appending .md to its URL.
The new Netlify experience is here. Learn more or join the waitlist.
How projects work
Whether you're new to Netlify or setting up your team, learn the basics of how projects work to help you manage your projects, access, and workflows.
Netlify organizes your work into three levels:
  • Organization workspaces (available for Enterprise plans)
  • Team workspaces (available on all plans, including Free and Personal plans)
  • Projects (Your sites or apps)
Nested diagram showing how organization, team, and project workspaces are related. The outermost box is the Organization workspace, available on Enterprise plans only, which manages more than one team workspace and provisions users at scale with Directory Sync and supported identity providers; it’s managed by an Organization Owner. Inside it is the Team workspace, available on all plans, which manages settings, members, and billing across projects and customizes project access; it’s managed by a Team Owner. Inside that is the Project, which is your site or app that you can publish on the web, customize, and make private, with different versions managed as deploys, such as previews (Deploy Previews) and the live production version.
Every project gets a default Netlify URL based on the project name:
https://your-project-name.netlify.app
To change your project name, check out Customize project name.
If you rename your project, the default URL changes to match. You can also connect a custom domain (like yoursite.com) so visitors don't see the .netlify.app address. Learn more about custom domains.
A "deploy" is a version of your project built on Netlify's infrastructure. You can have multiple deploys or versions of your project but only one live production version available at the production URL. This production URL can be the default Netlify URL that ends in netlify.app or it can be a custom domain you add to your project.
Netlify supports two main types of deploys or versions of your project:
  • Production deploys - uses settings for the production version of your project
  • Deploy Previews - uses settings for your project's previews
Netlify also supports branch deploys, which is another version of your project based on a Git repository branch. Branch deploys are less commonly used and require a connected Git repository and must be enabled for your project. Learn more about branch deploys.
Learn more about the basics of deploys.
