Skip to content
Netlify Docs
For the complete Netlify documentation index, see llms.txt. Markdown versions of any documentation page are available by appending .md to its URL.
The new Netlify experience is here. Learn more or join the waitlist.
Find a project
Learn ways to find a project from your Netlify dashboard.
Anyone on your Netlify team with access to your project can use the projects sort options from the Netlify dashboard to find a project.
You can sort by most recently published, last updated, and more.
Anyone on your Netlify team with access to your project can use the projects filter from the Netlify dashboard to find your project.
  1. From your Project overview dashboard, select Projects, then under the projects search box, choose Edit filters and choose your filters.
You can filter your projects by whether you created the project, by whether the project is protected by a password, a project label, and more.
To filter your team‘s site list by label, select a label on one of the sites in the list. You can also filter sites by selecting Filter by label and choosing the appropriate label.
Filter menu in the Sites list, which includes labels.
You can find a project by URL using the Command Palette, which is especially useful when you have a link from a teammate, a preview open in your browser, or only remember the custom domain.
  1. From your Netlify dashboard, press command+K on macOS, or ctrl+K on Windows and Linux, to open the Command Palette.
  2. Enter any of the following types of project URLs:
    • Project URL: the project’s Netlify subdomain, such as https://example-project.netlify.app.
    • Deploy Preview URL: a Deploy Preview for a pull or merge request, such as https://deploy-preview-42--example-project.netlify.app.
    • Branch deploy URL: a branch deploy, such as https://staging--example-project.netlify.app.
    • Permalink URL: a deploy permalink that starts with a deploy ID, such as https://1234abcd12acde000111cdef--example-project.netlify.app.
    • Netlify project dashboard URL: a link to the project’s dashboard in the Netlify UI, such as https://app.netlify.com/projects/example-project.
    • Custom domain: a domain you’ve assigned to the project, such as https://www.example.com.
  3. Select your project. Command Palette window with custom domain docs.netlify.com entered, then the docs project under "Projects"
You can only find projects on teams you belong to.
To close the Command Palette without selecting a project, press esc.
