For the complete Netlify documentation index, see llms.txt. Markdown versions of any documentation page are available by appending .md to its URL. Monitor activity in your project by checking out your project audit log, setting up notifications, or setting up Slack App notifications.
Check your project audit log
Section titled “Check your project audit log”Use your project audit log to check for critical changes to your project, such as:
- project configuration updates
- environment variablesenvironment variablesNamed values stored outside your code that your site can read at build time or runtime.
- deploy rollbacks (publishing a previous version of your project)
To check your project's audit log:
- From your Project Overview dashboard, go to Analytics & metrics Audit log .
Set up deploy notifications
Section titled “Set up deploy notifications”Set up notifications for your project's deploy activity.
Send deploy notifications to an email address, a pull/merge request on GitHub, GitLab, another Git hosting provider, or an external web service.
For example, you can send notifications for these deploy events:
- Deploy started
- Deploy succeeded
- Deploy failed
- Deploy deleted
- Deploy locked
- Deploy unlocked
- Previously successful deploy failed
- Previously failed deploy succeeded
Set up form notifications
Section titled “Set up form notifications”You can also set up notifications for forms activity in your project.
Use the Slack App to post notifications
Section titled “Use the Slack App to post notifications”For even more notification options, check out our Netlify App for Slack integration.
Did you find this doc useful?
